cbeck's avatar
cbeck
Orbi & Sonos - To SonosNet or not?
Currently have Sonos using Orbi wireless, as no nearby sosnos devices to wire direct to any speakers.  Performance to the 9 Sonos devices seems pretty good, but wonder if a Boost device would enhance...
  • st_shaw's avatar
    Jan 03, 2018
    I have ~9 Sonos devices running Sonosnet with Orbi in AP mode and it works perfectly.
    You do not need a Boost to use Sonosnet, as every Sonos device has the hardware necessary to operate as a mesh network.
    If you want to try it, all you need to do is plug in one, and only one, of your Sonos devices into Ethernet. Don't wire more than one Sonos device to Ethernet or you could potentially create a problem with network loops and crash your network.
    I would plug the Sonos device into your Orbi or Fios router for best results, so it's not also traversing the Orbi backhaul.  However, it should work with the one Sonos device plugged into a Satellite.  (I haven't tried that though.)
    For best results, you do need to manually set the 2.4 GHz  channel used by Sonos and by Orbi so they do not overlap. Set one on CH1 and the other on CH11.
    If you use Sonosnet, placement of the devices matters a lot.  Sonosnet cannot work properly unless the Sonos devices are placed where they can see enough neighbors to form a mesh. If necessary, you can place a boost or bridge in strategic locations around the house (no need to wire them) to improve mesh topology.
