shobuddy's avatar
shobuddy
Orbi & Verizon Fios ONT not Connecting
Hello, I just purchased an Orbi RBK50 (RBR50 & RBS50) and am having trouble setting it up. I currently have Verizon FIOS (internet only) service with a G1100 modem/router. The ONT feeds an ethernet cable into the house so I don't believe I need a modem. I should be able to plug and play the ORBI, however, the Orbi setup does not detect internet. Using the ORBI app, the setup stops where it says to make sure the ethernet cable is plugged into the router on one end and the modem on the other (they are plugged in).  Using the web setup, it stops when its searching for firmware updates and says it can't connect to the internet. Reading the forums, I saw another user suggest the IP needs to be released from the FIOS console but I'm not sure where that is in the FIOS settings or if that is even the solutions. Any input would be greatly appreciated.
  • I was actually trying to remove the G1100 and just use the Orbi router w/one satellite. I was able to figure out how to do the release and the Orbi is now online.  Thanks for your help!
