BallsJesus
Jan 10, 2017Tutor
Orbi 3-pack question
So I bought the 3-pack from Costco for $499 (RBK53). My house is a single-level at 2100sq ft. Probably overkill but I thought it may be worth it for the 2nd extra satellite for only $100 more basic...
Mikey94025
Jan 10, 2017Hero
I'm surprised your speeds are limited within your 2100 sq ft, between at least the middle satellite and the corner. Are you sure you measured the speeds on a device connected to the middle satellite and again with the same device connected to your router? We want to be sure the speed difference is due to the satellite backbone connection.
In the worse case, I'm sure you can sell your extra satellite since the retail price for an add-on is $250. Or just keep it for future use.
BallsJesus
Jan 10, 2017Tutor
Dumb question, but how do I know what device I am connected to when running the speedtest? Also, the speed tests vary SIGNIFICANTLY depending on what test platform I use, ie. speedtest app from Ookla, speedtest through Google search, or speedof.me site. The speedtest app from Ookla is a consistent 35+mb DL (which is fine since I only get about 45mb wired). The speedof.me and Google tests range from 2mb to 20mb DL max. Very strange. In any case, let me know how I see what I am connected to when running the tests and I will get you more data. I appreciate the response!
- swrtwdrvJan 10, 2017Apprentice
Yoiu can login to each satellite and click on Attached Devices to see what devices are connected, Uses same usename and password as your Orbi. You can get the satellite IP Address from the Orbi Attached Devices lists. Also see the the following thread: https://community.netgear.com/t5/Orbi/Orbi-satellite-and-genie-app/m-p/1203351#M2738
- TC_in_MontanaJan 10, 2017Virtuoso
You may be OVER saturating your house with the wireless signals. Each unit (Router and Satellite) is supposed to provide coverage for 2000 sqft. So, you are trying to cram 6000 sqft of signals into 2100.
Have you tried with just the router where it is and one satellite at the far end of the house, furthest away from the router? Are you using the wired connections from the other satellites for devices, or using wireless only? Unless you are specifically wanting to use the wired connections from the satellites, I would try dropping to 1 sat, or even try it with just the router to see if it improves your connectivity. If it does, you could definitely attribute it to over saturation.
While the router + 2 satellite kit at Costco is hard to pass up for the price, I think it may be causing some people more issues if they do not have a space that requres that much signal. As the other poster said - keep it for a spare, or find someone who just wants to buy the router and sell him/her the extra satellite.
- BallsJesusJan 10, 2017Tutor
I tried the telnet option in your link but unfortunately I cannot telnet into my router as it gives me an error...story of my life. "Error while connecting to the host - could not open a connection to host on port 23" So there's that...
Below is a pic of what my "Attached Devices" screen looks like. As you can see, it doesn't tell me what devices are connected to what satellite, etc. Also, several unknown devices with same MAC, I can only assume it is my DirecTV but there are only 3 boxes for that so not sure why there are 5 unknowns? Also, my printer doesn't show up and that is connected. Weird.
Ideas?
THANKS ALL!!!
- djc6Jan 10, 2017Luminary
BallsJesus wrote:Below is a pic of what my "Attached Devices" screen looks like. As you can see, it doesn't tell me what devices are connected to what satellite, etc.
See in screenshot the IPs of the satellites - 10.0.0.3 and 10.0.0.8 ? Go to those IPs in your browser and you'll see what devices are connected to those satellites. The satelittes have a web page interface too.
If you end up only needing two satellites, you may be able to sell the third one for more than the $100 difference you paid :) That was my thinking when I got the three pack.
