Dhuffstu's avatar
Nov 29, 2018
Orbi AC 2200 12V/1.5A power adapters replacement (need: 220V 50hz)
I have the AC2200 RBK23. Just realized it does NOT have dual voltage power adapters (wall plugs). Can anyone recommend a 220V 50hz replacement? Thank you!
  • Additionally: Specs on power adapter are: Input: 110-120V 50/60Hz .6a | Output: 12v 1.5a
  • michaelkenward's avatar
    michaelkenward
    Any generic adapter works as long as it has the right volts and enough amps, along with the correct tip and polarity.
    Sometimes these things tell porkies. The label says one thing but the device knows better.
    People have take their life into their hands and tested the thing at the "wrong" voltage. Only to discover that it works for some Netgear adapters. I wouldn't know about your adapter. Maybe someone else has tried it.
    I doubt if support can help. Netgear doesn't sell spare adapters. Third party suppliers are all over the place.
