LaSabana's avatar
LaSabana
ORBI AC 2200; RBK20W
Hello,
I thought I might reach out once again to this community to see if anyone can offer a step by step process to resolve an ongoing issue with my Orbi.
My current NG Firmware is:v2.3.5.26. Currently, Windows10 Home v1903; OS build 18362.67.
I installed this Router/Satellite in Sept 2018. Within the 90 day warrenty period I contact ORBI support 4x. The issue that i was and still experiencing is when I have the ethernet 5e cable connected from the ORBI ethernet to my computer ethernet I can navigate the internet for a couple hours when I lose the page and receive a message "..Hmm this page is not responing.. cannot locate page". And this necessitates me to disconnect the ethernet connection and return to WiFi at which time I can once again navigate w/o issue. On a previous post on this community an individual indicated that this issue is known by ORBI should resolve with a following Firmware update also, this individual recommended setting changes to Diasy chain and MIMO??. The firmware updates to did not change this performance. When I initailly contacted ORBI support, two separate individuals had me change some DNS settings and while this seemed to correct the issue the problem return w/in a couple of days. Can anyone provide a process or changes that I can apply so that I can use the faster ethernet connection? Thank you.
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    How many RBS do you have deployed? 1 or 2? Daisy chain is only needed for 2 or more satellites when placed out in a line from the RBR.
    Are you wire connected to the back of the RBR or RBS?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    • LaSabana's avatar
      LaSabana
      Thank you FURRYe38 for your detailed reply much appreciated. The ISP modem is ARRIS SB6190. I am not sure but I assumed that the ORBI is in the router mode. And I am connected to the router in fact, my 5e cable is connected to the ethernet that is located on the back of the router and to my computer which is about 4ft away.  I have one Satellite which is 45-48 ft from the Router base; home is 1350sqft.
      FURRYe38, I just want to be clear that I am not experiencing any issue on the WiFi side in fact, my ISP is providing 150mbps and i am seeing on ORBI internet speed 175 up and 6.00 down. And we do have many WiFi users in the area. So your thought is to try the last 3 sentences of your reply:
      What channels are you using?.Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless SettingsTry disabling the following and see:
      Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Thank you
      • FURRYe38's avatar
        Try this, power OFF both ISP modem and RBR for 1 minute, then power ON the ISP modem and let it sync. Then power ON the RBR.
