markjc100
May 18, 2026Aspirant
Orbi AC 3000 starting to fail - normal?
Hi, my Orbi AC 3000 was bought in 2020, and has recently started to fail or work suboptimally (not meshing well, not supplying normal broadband outputs - or at all etc). Is this normal for a product ...
markjc100
Thanks I have turned it off a few times, but will now try the unplugging aspect as well. I've had it working for c.6 years or so without changing anything so was trying to understand what the problem might be, since I haven't done anything different. A quick internet search said that the product might be near the end of its life.
May 18, 2026Guru - Experienced User
Possible that your environment or neighboring conditions have changed thus maybe causing some new odd behaviors that were not seen before.
Yes the Orbi AC series is EoL, however doesn't mean it can't still work well for you. May just need some troubleshooting first.
NG updated the FW I believe for one last time so that available if needed.
What Firmware version is on the system?
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
