irishman530
May 09, 2018Aspirant
Orbi AC2200 and Circle SSL Cert issue
Router: RBR20 Orbi AC2200
Firmware: version 2.1.4.10
OS: Windows
Browser: Chrome, Firefox, IE, Edge
I've got my Orbi setup, and it works pretty well. The only problem I am having is with ...
- May 09, 2018
I figured out my problem.
I had miscategorized the device I was using. I had it under the wrong profile so it was being filtered and restricted.
Take note Netgear Team and Circle Team. There needs to be a solution for HTTPS calls other than displaying a SSL/Cert error. It should be displaying "you've been filtered" message.
irishman530
joyijo
May 19, 2018Aspirant
How did you fix this?
Im having issues every time I try to login to Facebook, Instagram, eBay, Kijiji and other applications.
Thank you
Thank you
