cybergrafx
Dec 10, 2017Follower
Orbi AC2200 RBK30 working with Netgear N600 C3700 Cable modem
I'm not knowledgeable in this area. I'm setting up my new Orbi with an existing dual band Netgear Cable Modem. Does the Cable modem wifi interfere with the Orbi system? Is it better to turn the wifi ...
- Dec 12, 2017
You will need to bridge your cable modem and make it modem only and orbi broadcasts 1 SSID and will put your devices on the correct band.
https://kb.netgear.com/27191/How-to-set-the-cable-modem-router-to-be-on-modem-only
DarrenM
DarrenM
Dec 12, 2017Sr. NETGEAR Moderator
DarrenM
