RCamilleri
Dec 04, 2018Follower
Orbi AC2200 won't connect to internet
Hi there, I am hoping someone can help me. I just bought a Netgear Orbi AC2200 router and 2 satellites to strengthen my internet for my parents as they have just moved into our granny flat and they c...
Dec 05, 2018Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
