bob927
Jan 23, 2018Follower
Orbi ac2200
Currently using 2wire wifi router that connects to service with phone wire. How do I connect Orbi AC2200 and what are the issues. Please speak plain english and not techspeak as I am new to this. Thanks.
1 Reply
- DarrenMSr. NETGEAR Moderator
You will either need to change a setting in your modem to make it a modem only to disable its router if you can not do that during the setup of Orbi you would need to set it to AP mode. This will make sure you are not running into issues running 2 routers.
DarrenM
