YancyD
Sep 23, 2020Aspirant
Orbi AC2200
Does Orbi AC2200 Mod #RBK20W-100NAS work with DSL?
Sort By
without a dsl modem? no.
if there's a dsl modem/router prior to it? then yes you can connect the orbi to it.
- YancyDAspirant
Thanks. Do you know if there are any Mesh router/modems available for DSL?Orbi doesn't have any with a dsl modem integrated. But you can use your standard modem/dsl router that you have an put it in modem only/passthrough mode. In that mode you can hook up an orbi setup to it
