buckleyje5
Feb 01, 2018Tutor
Orbi AC3000 drops internet EVERY NIGHT
First off, we have the Netgear Nighthawk Docsis 3.0 Cable Modem Router (with the WIFI disabled) running a wired connection to our Orbi- and we have 2 sattelites.
Every Single Night the wifi drops around 9:30pm. Every. Single. Night.
The wired connection from the Nighthawk is still working though- I can use our desktop computer. Just no wifi capabilities in our home. Which leads me to believe it's an Orbi thing.
Why is this happening and what do I need to do?
- DarrenMSr. NETGEAR Moderator
Are you running Orbi in router mode or AP mode?
DarrenM
I just switched to AP mode, but now my RING doorbell camera has a HUGE delay, so I'm going to move it back to Router mode.
BUT.... I did see that the "lease" was always ending at 9:30pm and I'm thinking that's why the glitch every night at that time. When I woke up the next morning super early (5:15am) I renewed the lease- so now it expires while we are all still aslee in bed and not trying to use our laptops.
I'm thinking THAT was the fix!
UPDATE: Nope, it's down again. The "lease renewal" didn't work. I have internet on my wired device from my primary router- but anything coming from the Orbi does not work.
HELP!! Why does Orbi crash every night at the same time??
- RoamaboutLuminary
What if you run the Orbi router in AP mode and give it a static address. Does that change the behavior ?
I did try the AP mode, and we didn't have any drops for several days.....BUT for some reason it made our Ring doorbell have a 10-second lag. So I switched it back.
I don't know enough about networking to understand static IP, but when I read the log at the time internet disconnects, there's always a DHCP IP entry- so I thought about disabling the DHCP and moving to static IP, but does that mean I have to manually assign an IP to every device in our house? Or will it keep the ones it has? And what happens if a device leaves our house- will it reconnect when it comes back?
This is above my paygrade :)
