Noroddveien
Jan 23, 2019Apprentice
Orbi AC3000 (RBR50) and IPTV via Telenor
Hi, I recently subscribed to Telenor (ISP) fiber internet here in Norway. I previously had cable internet with coaxial TV connections. With Telenor´s fiber network, coaxial connections to TVs are no ...
- Apr 28, 2019
Eureka!!
IPTV is now working 100% together with my Orbi RBR50 (without my ISP (Telenor) router). I upgraded my RBR50 from FW V2.2.1.210 to V2.2.1.212 and finally to V2.3.1.48 and suddenly all my IPTV problems went away. Thank you Netgear for the fix.
Jan 23, 2019Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
You can try option #2 and see if this works for you, if not, I recommend you give option 3 a try...
Noroddveien wrote:
Hi, I recently subscribed to Telenor (ISP) fiber internet here in Norway. I previously had cable internet with coaxial TV connections. With Telenor´s fiber network, coaxial connections to TVs are no longer possible. All TVs need to be connected to the home network via ethernet when connected as IPTVs. This works fine when using the Telenor-supplied Zyxel P8702N router. The router connects to a T-We decoder and then to the TV. However, I have a state-of-the-art Netgear Orbi mesh system which includes a RBR50 router. I would think the RBR50 is technically capable of handling IPTV but am having problems. I am trying to connect as follows:
Fiber ONT -> RBR50 -> T-We -> TV
Fiber ONT : NOKIA G-010G-P
Router: Netgear Orbi, RBR50
TV decoder, T-We: ADB 5743CDX
TV: Sony Bravia (connected via HDMI cable to decoder)
I have set RBR50 up using IGMP proxying which I understand enables multicast. SIP ALG is also disabled. In addition, I have enabled IPv6. After this setup, everything is 90% fine, however the TV picture will freeze now and then. Also, I need to turn the T-We box off/on to get back to a live broadcast when it freezes.
I’ve read several articles stating that VLAN may be required for IPTV but have not succeeded in getting it to work (the internet connection fails etc).
Anyone out there that has succeeded in setting up RBR50 with IPTV? I do not want to have to use the Zyxel at all (e.g. bridge mode).
Noroddveien
Thanks for your quick response. However, please note that I asked for a solution that involves not having to employ the Telenor Zyxel router. I´m sure there must be a way to configure RBR50 so that it can handle both data and IPTV without the Zyxel. By the way, the "modem" in the case of my fiber optic connection is the Nokia G-010G-P.
- FURRYe38Jan 23, 2019Guru - Experienced User
You'll need to ask your ISP if there router can be removed and then replaced by the Orbi system. If so, then have them give you information on any configurations needed by Orbi to work in place of there router. Some ISPs require use of there router so reason why I gave suggestions to connect the Orbi system to there router.
By the looks of the manual for the Nokia, it seems that the Nokia handles the input SC/APC fiber optic connection as well as output of RJ45 LAN port: Page 1-4
https://fccid.io/ANATEL/03080-16-08076/Manual-do-Produto/F30E7DF7-7334-4F5D-9FAF-FC6FB21184B1/PDF
You probably need the Nokia in place.
Hope the ISP will be able to answer this for you.
https://kb.netgear.com/31032/Does-Orbi-replace-my-modem-or-gateway
https://kb.netgear.com/31100/How-do-I-set-up-my-Orbi-system-to-work-with-Fios
- NoroddveienJan 24, 2019Apprentice
Thanks FURRYe38, yes I am begining to realize that I will need to contact the ISP (Telenor) for configuration details. I had hoped to avoid calling their expensive service telephone (26NOK/min). And, yes, the Nokia ONT definitely needs to kept in place.
- FURRYe38Jan 24, 2019Guru - Experienced User
Ok, thanks for letting us know. I know it can be a pain to contact ISPs. Hopefully they can help you with the system.
Again, if you don't get anywhere with the ISP, change the Orbi to AP mode and let the ISP modems be your router. Try to keep it easy for you and with less hassel I guess.
