tyker504
Apr 20, 2020Tutor
orbi ac3000 slow LAN speeds
I bought an Orbi a few months back and it was functioning fine. When i did my first speed test after setting it up i was getting pretty good speeds. I pay for 1 GB x 1GB Fiber from AT&T. As of recent...
Apr 20, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Wouldn't happend to be a ARRIS-BGW210-700 would it?
- tyker504Apr 20, 2020Tutor
it is indeed a Arris BGW210-700
- FURRYe38Apr 20, 2020Guru - Experienced User
Ok, been others posting having same or simiar problems with this system and this particular modem.
Try the Orbi system in AP mode yet?
Some things to review:
https://www.f0il.com/how-to-arris-bgw210-700-modem-router-with-netgear-xr500-router/
https://community.netgear.com/t5/Orbi/How-do-I-setup-bridge-mode-in-the-ARRIS-BGW210-700/m-p/1875994/highlight/true#M84982
ATT Dumb Swiith Method:
https://community.netgear.com/t5/Orbi-AX/Orbi-AX-6000-and-AT-amp-T-fiber-gateway-issue/m-p/1890125/highlight/true#M2756https://community.netgear.com/t5/Orbi/Installing-Orbi-behind-ATT-Pace-5268AC-gateway/td-p/1234191
https://community.netgear.com/t5/Orbi/Netgear-Orbi-and-ATT-Pace-5268-Router/m-p/1786833/highlight/true#M68004
https://community.netgear.com/t5/Orbi/ATT-fiber-BGW210-and-costco-RBR50-RBS50/m-p/1868313#M83488
Modem FW may have broke good speeds between the modem and Orbi in router mode:
https://community.netgear.com/t5/Orbi/RBK50-Speed-Throttling-Wired-and-Wireless/td-p/1673291/jump-to/first-unread-message
https://community.netgear.com/t5/Orbi/How-I-fixed-our-intermittent-internet-connectivity-problems-with/td-p/1688722/jump-to/first-unread-message
https://community.netgear.com/t5/Orbi/Orbi-RBR50-Slow-Wired-WAN-after-2-2-1-210-Upgrade/m-p/1676934/highlight/true#M47457Seems to be problematic for Orbi and this modem.
Orbi does work on 1G ISP with cable modems:
https://community.netgear.com/t5/Orbi/Orbi-RBR50-is-not-supporting-900Mb-on-the-WAN-to-LAN-test/m-p/1827295/highlight/true#M76372
https://community.netgear.com/t5/Orbi/New-RBR50-Satellite-setup-some-thoughts-and-questions/m-p/1695161/highlight/true#M50762
https://community.netgear.com/t5/Orbi/Download-speed-cut-in-half-on-wired-connection/m-p/1695372/highlight/true#M50815- tyker504Apr 20, 2020Tutor
intresting.... I will try disabling the firewall on the BGW the modem is already in passthrough as i have static IP addresses in a block of 5 and i manage what IP im using from my Orbi. I do have some dummy switches laying around if that does not fix the issue. Thanks for help. I will mark as solved once i confirm one of the two methods you posted confirms fixes my solution.
