tyker504
Apr 20, 2020Tutor
orbi ac3000 slow LAN speeds
I bought an Orbi a few months back and it was functioning fine. When i did my first speed test after setting it up i was getting pretty good speeds. I pay for 1 GB x 1GB Fiber from AT&T. As of recent...
Apr 20, 2020Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Wouldn't happend to be a ARRIS-BGW210-700 would it?
tyker504
Apr 20, 2020Tutor
it is indeed a Arris BGW210-700
- FURRYe38Apr 20, 2020Guru - Experienced User
Ok, been others posting having same or simiar problems with this system and this particular modem.
Try the Orbi system in AP mode yet?
Some things to review:
https://www.f0il.com/how-to-arris-bgw210-700-modem-router-with-netgear-xr500-router/
https://community.netgear.com/t5/Orbi/How-do-I-setup-bridge-mode-in-the-ARRIS-BGW210-700/m-p/1875994/highlight/true#M84982
ATT Dumb Swiith Method:
https://community.netgear.com/t5/Orbi-AX/Orbi-AX-6000-and-AT-amp-T-fiber-gateway-issue/m-p/1890125/highlight/true#M2756https://community.netgear.com/t5/Orbi/Installing-Orbi-behind-ATT-Pace-5268AC-gateway/td-p/1234191
https://community.netgear.com/t5/Orbi/Netgear-Orbi-and-ATT-Pace-5268-Router/m-p/1786833/highlight/true#M68004
https://community.netgear.com/t5/Orbi/ATT-fiber-BGW210-and-costco-RBR50-RBS50/m-p/1868313#M83488
Modem FW may have broke good speeds between the modem and Orbi in router mode:
https://community.netgear.com/t5/Orbi/RBK50-Speed-Throttling-Wired-and-Wireless/td-p/1673291/jump-to/first-unread-message
https://community.netgear.com/t5/Orbi/How-I-fixed-our-intermittent-internet-connectivity-problems-with/td-p/1688722/jump-to/first-unread-message
https://community.netgear.com/t5/Orbi/Orbi-RBR50-Slow-Wired-WAN-after-2-2-1-210-Upgrade/m-p/1676934/highlight/true#M47457Seems to be problematic for Orbi and this modem.
Orbi does work on 1G ISP with cable modems:
https://community.netgear.com/t5/Orbi/Orbi-RBR50-is-not-supporting-900Mb-on-the-WAN-to-LAN-test/m-p/1827295/highlight/true#M76372
https://community.netgear.com/t5/Orbi/New-RBR50-Satellite-setup-some-thoughts-and-questions/m-p/1695161/highlight/true#M50762
https://community.netgear.com/t5/Orbi/Download-speed-cut-in-half-on-wired-connection/m-p/1695372/highlight/true#M50815- tyker504Apr 20, 2020Tutor
intresting.... I will try disabling the firewall on the BGW the modem is already in passthrough as i have static IP addresses in a block of 5 and i manage what IP im using from my Orbi. I do have some dummy switches laying around if that does not fix the issue. Thanks for help. I will mark as solved once i confirm one of the two methods you posted confirms fixes my solution.
Sounds good. Hope something works out to get the speeds up. Keep us posted.
"this issue was happening on the previous version of the firmware as well. '"
