JimLevesque
Jul 24, 2017Follower
Orbi AC3000 Tri-Band system from Costco - Unable to place router in center of the house
I purchased this from Costco and unfortunately cannot locate the router in the center of the house. The incoming internet signal is in a back bedroom (so the router is placed there), and 1 satellite...
cyberprashant
Jul 24, 2017Luminary
if it's cable, run a cable line to the center of the house - thats what I did. Orbi RBK50's coverage range is pretty awesome you might do okay even on one end of the house.
- cue003Jul 24, 2017ApprenticePut the furthest satellite back in the box and run with only 2 (main Orbi + 1 satellite). That may give you the best coverage without interference and overlap from the 3rd unit.
