JimLevesque
Jul 24, 2017Follower
Orbi AC3000 Tri-Band system from Costco - Unable to place router in center of the house
I purchased this from Costco and unfortunately cannot locate the router in the center of the house. The incoming internet signal is in a back bedroom (so the router is placed there), and 1 satellite...
cyberprashant
Jul 24, 2017Luminary
if it's cable, run a cable line to the center of the house - thats what I did. Orbi RBK50's coverage range is pretty awesome you might do okay even on one end of the house.
cue003
Jul 24, 2017Apprentice
Put the furthest satellite back in the box and run with only 2 (main Orbi + 1 satellite). That may give you the best coverage without interference and overlap from the 3rd unit.
