sclawrenc's avatar
sclawrenc
Apprentice
Nov 19, 2019
Orbi AC3000 using Wired Backhaul with Edge Router 4
I'm considering placing the Orbi in Access Point mode using wired backhaul and using an Edge Router 4 as my wired router.  Everything is currently working fine with my Orbi, and I'm just wanting to tinker in the Edge Router 4 world.
Anyone have any suggestions regarding this setup?  Does it work fine?  Any issues or things I should think about?
Thanks in advance!
  • FURRYe38's avatar
    Yes, AP mode works just fine. Had a ER-X connected at one time with the Orbi in AP mode. Keep the RBS directly connected to the RBR or use a non manged, non green ethernet switch in between the RBR and RBS.
    • sclawrenc's avatar
      sclawrenc
      Apprentice
      Thanks. Do you think it’s any faster using a stand alone router like the er4?
      • FURRYe38's avatar
        I would look at the specs of the ER4 router. I know that the ERX router only supports up to around 300Mbps WAN to LAN. I recently updated to 1Gb WAN to LAN so I can't use the ERX router currently. If the ER4 supports your ISP speeds WAN to LAN, can try it and see how you like it. There UI is a bit more complex and not as easy as NGs UI. Meant for the advanced networking users or IT pros.
