BobDuke
Dec 17, 2017Apprentice
Orbi AC3000 Working
I've seen a number of postings from those that have had problems with their Orbi system. I know that issues with any product occur. I know that there are always features that would be helpful - I c...
tagteam
Dec 17, 2017Virtuoso
I have an RBK53 system from Costco. I purchased the system several months ago, but waited to set it up until September (after the switch from Comcast to Summit (fiber) was complete). The system came with v1.4.0.18 which, at some point, auto-updated to v2.0.0.74 (and I'm still on that version). I am running in router mode and have had zero issues......thus far.
With respect to attached devices, that would be 4 Windows 10 PCs (2 wired to the router, one wired to a Sat, one wireless), 3 Brother printers, 2 iPads, 3 iPhones, 1 Samsung Network Extender (wired to the router), 1 Chromecast, 1 Fire TV Stick, and 1 TV.
Backhaul is 5G wireless and there are two walls between the router and the Sats, which are around 35-45 feet from the router.
godspeed
I have now purchased 2 sets of the RBK50, one from Amazon a few weeks ago, and the other from Walmart a few days ago. My intent on the Walmart purchase, was to try and rule out the possiblity of the Amazon version being a bad hardware version. On the amazon version, on both 2.0 and 2.1 firmware's, constant reboots occur on the satellite and the router, as noted by the system uptime resetting on the debug.htm pages.
I installed 2.0 and 2.1 on the Walmart version as well, and, unfortunately, same problem. I downgraded to 1.11, and for the last 12 hours, its been running fine, so far.
I did notice that the box for the Orbi is different between the 2 versions (amazon and walmart). the walmart one has the router and satellite sitting on top of each other, whereas the amazon box had them side by side standing up, with the power supply box between them.
I use an Asus router for routing, and have the Orbis in AP mode. I have done every combination of wireless settings and placement that i can think of (I am a fairly technical person), multiple factory resets, etc on the Amazon version, but i finally packed it up and sent it back for refund today.
I'm hoping the Walmart version (manufactured in 9/2017) fairs better, but i have an Eero Gen 2 with 2 beacons on its way from Amazon, just in case.
I really want the Orbi to work for me, as its perfect for my needs, but it has to be something that i can set and forget, not something i have to constantly monitor and tweak just to work, from firmware to firmware version.
- BobDukeDec 17, 2017Apprentice
Where do I find the manufacture date?
- godspeedDec 17, 2017Apprentice
I found a sticker on the walmart box that had a date of 9/2017...sorry, this may not be the manufactured date, but the date that walmart received it in their stock.
my apologies for any confusion!
- netgearguyDec 17, 2017Apprentice
I think you'll find the Eero Gen 2 system pretty flawless in terms of "just working." Mine has be absolutely boring overall (in a good way) since I set it up. I think the Orbi setup I had (the "lesser" RBK30 system) had overall faster throughput, but as we all know, that came at a high price in terms of disconnects.
Interesting the differning packaging. My RBK30 system also had the two units on top of each other, satellie below, router above, both laying down. I've already returned it or I would look for a manuf. date. When my next set arrives (from Amazon) I'll be interested to see which packaging I get.
- Retired_MemberDec 18, 2017
netgearguy wrote:I think you'll find the Eero Gen 2 system pretty flawless in terms of "just working." Mine has be absolutely boring overall (in a good way) since I set it up. I think the Orbi setup I had (the "lesser" RBK30 system) had overall faster throughput, but as we all know, that came at a high price in terms of disconnects.
Bought my Orbi from Costco last month. So far it's been fine. It did a firmware update upon install and since then I haven't touched it. I beleive I'm at 2.0074..?? I don't do manual updates. At any time I may have 20+ devices online. This morning I did get the infamous Blue-Light constant 'ON' with one of the Sats. May end up dong a power reset.
