davness
Apr 18, 2018Aspirant
Orbi AC3000
I bought a Orbi mesh and right now I have a Nighthawk ac1900 C7000 modem router, can I connect the orbi without any problems? or I need to turn off the wifi on my modem?
Apr 18, 2018Guru - Experienced User
Couple of options,
Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router modem.
Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
What FW version is the Orbi currently using?
davness
Apr 19, 2018Aspirant
I have a nighthawk ac1900 c7000 but does not have the option for bridge mode, I look everywhere and online and nothing, I try with a TP-Link modem TC-7610-E but the Orbi router never setup, got online for a couple of seconds and when I try to go to the next step just lost internet signal, then I power off and on and the same thing happen every time, I connect my pc to the router and the internet was fine, so I think I just going to return ut and look for another alternative
- davnessApr 19, 2018Aspirant
I connect the PC to the modem no to the router and the internet was fine, I'm thinking in return the orbi or get a c1000 modem, but I'm not sure that will work if I try that
