diamondscar
Oct 22, 2016Star
Orbi Access Control Firmware 1.3.0.12
I just updated my Orbi Router and Satellite to the latest firmware, 1.3.0.12. I'm using Access Control to limit access to the network. I have a Tivo Mini hooked up to the ethernet port of the satel...
dpdurst
Oct 22, 2016Luminary
If its truly hung in the software you go to Administration and then Backup and try to erase and default the Orbi and see if this resolve the issue then.
peteytesting
Oct 22, 2016Hero
dpdurst wrote:If its truly hung in the software you go to Administration and then Backup and try to erase and default the Orbi and see if this resolve the issue then.
yup click on
revert to factory default settings
allow the orbi to restart and redo the initial setup
