diamondscar
Oct 22, 2016Star
Orbi Access Control Firmware 1.3.0.12
I just updated my Orbi Router and Satellite to the latest firmware, 1.3.0.12. I'm using Access Control to limit access to the network. I have a Tivo Mini hooked up to the ethernet port of the satel...
diamondscar
Oct 22, 2016Star
Thanks for all the input. I'm not going to do anything since it's only an interface issue and not something that's actually affecting the functionality. If it gets to the point where I need to block or unblock something and I can't, I'll try the backup/factory default route. I just thought Netgear should know and see if anyone else had the issue.
- DarrenMNov 30, 2016Sr. NETGEAR Moderator
Hello everyone
The Access control bug should be fixed in the latest Firmware 1.4.0.16 can someone confirm that this has resolved the issue.
Thanks
DarrenM
- diamondscarNov 30, 2016Star
Unfortunately, this appears to persist for me. I've tried allowing it, blocking it and re-allowing it, and manually editing the access. None have worked. It still says "blocked" but continues to be able to access the network.
- Hydro130Nov 30, 2016Luminary
DarrenM wrote:Hello everyone
Thanks
DarrenM
My Hue bridge and SmartThings hub are still both "Blocked" with 1.4.0.16 - they've both been that way with the previous 2 f/w versions too (that's when I got the Orbi).
Both devices work have always worked perfectly fine though, so it's nothing I'm losing any sleep over it. Just an annoying thing to see in that Devices listing, but whatevs, no big deal.
Cheers, Chris
Thanks for letting me know I will report this back to the engineers.
DarrenM
