marcman12345
Apr 30, 2018Aspirant
Orbi and Airplay issue with Marantz SR7009 receiver
I'm having an issue with my marantz receiver and the Orbi RBR/RBS50. The receiver is hardwired to the Orbi and is set with a static IP. If I reboot the receiver, airplay will work for a short time bu...
Apr 30, 2018Guru - Experienced User
What FW version is loaded on the Router?
What is the IP address pool range set on the router? 192.168.1.2 thru .254?
marcman12345
V2.1.4.10
192.168.1.2 thru .254 - yes. The receiver is set at .202
