marcman12345
Apr 30, 2018Aspirant
Orbi and Airplay issue with Marantz SR7009 receiver
I'm having an issue with my marantz receiver and the Orbi RBR/RBS50. The receiver is hardwired to the Orbi and is set with a static IP. If I reboot the receiver, airplay will work for a short time bu...
Apr 30, 2018Guru - Experienced User
Is the Static IP address set ON the RCVR or the router?
Try setting the IP address pool, from 192.168.1.100 to .200. Static IP addresses should be outside of a default IP address pool, not inside. And should be ON the device, not the router. Reservations are set ON the router for devices.
IS the RCVR the only device that looses connections?
Where is the RCVR connected? Router or Satellite?
- marcman12345Apr 30, 2018Aspirant
The static IP is set on the receiver, I also have it reserved on the router but will remove the reservation and change the address pool.
The receiver doesn't lose the connection, it's literally just the airplay functionality. Airplay works just fine to my various Apple TV's, it's just airplay to the receiver that diasppears quickly. The rest of the receiver functions remain online. That's why I'm thinking there isnt a specific port opened up or something is crashing that functionality in my receiver possible?
Receiver is connected to the router
