marcman12345
Apr 30, 2018Aspirant
Orbi and Airplay issue with Marantz SR7009 receiver
I'm having an issue with my marantz receiver and the Orbi RBR/RBS50. The receiver is hardwired to the Orbi and is set with a static IP. If I reboot the receiver, airplay will work for a short time bu...
Apr 30, 2018Guru - Experienced User
Yes, remove the reservation, you can only set up a static or reservation at one time, not both.
Well if the app is working for a time then stop, I presume it would be a configuration that needs to be looked at...Lets see if changing the IP config around helps first.
Is uPnP enabled? It should be by default.
- marcman12345Apr 30, 2018Aspirant
I only enabled the reservation this morning, it didn't seem to make a difference. Yes, uPnP is enabled
- FURRYe38Apr 30, 2018Guru - Experienced User
Let us know if changing the IP config around doesn't anything different. There is some Apple HomeKit issues posters are posting about. Could be an issue as well for AirPlay....
Might try a factory reset on the router and set up from scratch and see if the problem continues. Might also try to revert back to last working FW version as well...
