TropicalDoc
Sep 06, 2018Initiate
Orbi and Arlo Pro 2 Camera
I have the Orbi router with 3 Satellites connected. I purchased the Arlo Pro Wireless Camera system and have 5 cameras hooked up to it. My question is :
Is there a way to hook the Arlo Base stati...
Christian_R
Sep 06, 2018NETGEAR Employee Retired
Hi TropicalDoc,
Thank you for reaching out to the community for suggestions. Unfortunately, this configuration would not work. However, if most of your cameras capture good Wi-Fi in an area where one of your satellites is set up, you may want to connect your Arlo base station to that satellite.
For other configurations from other Arlo community members, I suggest you look into the Arlo Community:
https://community.arlo.com/t5/Arlo-Smart-Home-Security/ct-p/Arlo
~Christian
- TropicalDocSep 06, 2018Initiate
Can I purchase a second base station or Netgear wifi extender to add range to the current syste?. Unfortunately all my cameras cannot be captured by the wifi of just one satellite. Cost is not an problem, I just want to solve the issue.
Thank you
- Christian_RSep 06, 2018NETGEAR Employee Retired
Hello TropicalDoc,
Yes, you may use a second base station to extend the range of your cameras as mentioned in this Arlo thread.
https://community.arlo.com/t5/Arlo-Pro/Two-base-stations/td-p/1282848
~Christian
