jjon90
Oct 03, 2016Guide
Orbi and Arris touchstone TG2472 (Cox )
I can confirm that Orbi worked seamlessly with my Cox cable/wifi/telephone modem! I did shut down the wireless capability in the Arris prior to the Orbi setup! Orbi did improve the speed and connection reliability so far being 10 hrs into the Orbi/Satellite setup.
- DarrenMSr. NETGEAR Moderator
Hello jjon90
Great to hear let us know if you need help or run into any issues.
DarrenM
- TrikeinLuminary
How did you set it up? That gateway is not capable of being bridged because it has phone service attached to it. You should still disable the wireless on the gateway if you don't mean to use it. It will only mess with the Orbi wireless.
