jules2323
May 08, 2018Aspirant
Orbi and BT Home Hub 4
Hi,
My setup consists of a BT Openreach DSL box which in turn is connected via ethernet to my BT Home Hub 4. I have disabled wifi on the home hub and plugged my Orbi in .. in router mode. Every...
jules2323
Thanks for the reply. Unfortunatly internet tells me BT Home Hub 4 does not support bridge mode. DMZ option looks limited.
So I guess, access point mode or I by something like a Netgear DM200 to replace the home hub 4?
Or live with the seperate subnet
May 08, 2018Guru - Experienced User
Give the DMZ a try...should work for Orbi in router mode.
I would check with your ISP first to see what they support or BYOM.
Some say that the DM200 is not a good modem.
