myraid1
Feb 27, 2018Aspirant
Orbi and Circle. How/When will we be able to enable
So I have the RBR50 with the RBS50 and RBS40 Satellites. I am curious to know how I can enable Disney cirlce on the system? Are we still waiting for a firmware update for this type of compatibilit...
nicholb
Feb 27, 2018Luminary
Netgear pulled the 2.1 firmware that supports Circle. When they re-release that or 2.2, support should come back.
myraid1
nicholbwrote:Netgear pulled the 2.1 firmware that supports Circle. When they re-release that or 2.2, support should come back.
Thanks for the update.
- martyfpFeb 27, 2018Luminary
FYI - I am using Circle with 2.1 firmware. Seems to work quite well.
- myraid1Feb 27, 2018Aspirant
martyfpwrote:FYI - I am using Circle with 2.1 firmware. Seems to work quite well.
Thanks. After reading all of the issues on here with v2.1, I will wait till they have stabilized the new firmware. With the exception of my ethernet backhaul, my system is running very smoothly.
I must be one of the lucky ones 2.1 works pretty well for me.
