Ablac
May 07, 2017Guide
Orbi and CUJO working together
So I have an Orbi system (2 Sat) and I have a CUJO firewall. I wanted to share with everyone a way to get this working!!! It's quite a pain, but after spending 5 hours on the phone with CUJO support ...
Ablac
May 07, 2017Guide
i don't know then, but from my tests my wifi is much more stable, with my Satellites staying online, and Orbi is able to see them for auto updates, as well as all my devices are still protected by CUJO. It might have been a fluke thing with my Orbi's and my CUJO (Which GetCujo support named it "The Rebel CUJO" for many reasons as my CUJO is extremelt defiant.
But for anyone having problems with the Satelittes connecting through CUJO, or other connectivity issues while using CUJO and Orbi (Or other mesh network devices) this seems to solve nearly every problem, as Orbi is acting much closer to how it was intended, And CUJO still sees all the devices connected.
TheEther
May 07, 2017Guru
I'm glad it's working for you. Honestly, I think it would be easier to use the CUJO in bridge mode. That is, connect the CUJO between the modem and the Orbi. This way, you can avoid all this nonsense with DHCP, double subnets, double NAT and looping through the router. What a mess.
