Ablac
May 07, 2017Guide
Orbi and CUJO working together
So I have an Orbi system (2 Sat) and I have a CUJO firewall. I wanted to share with everyone a way to get this working!!! It's quite a pain, but after spending 5 hours on the phone with CUJO support ...
ryanovelo
May 16, 2017Initiate
I tried this last night. It doesn't work. A few questions to clarify:
- When you say "Satellite" are you referring to the satellite only (and not the main router)? I have 1 main router and 1 satellite - 2 units total.
- So if x is the number of satellites + 2, I would be 10.0.0.3? If so, that would be 10.0.0.3 to 10.0.0.3.
- Did you assign the main router the ip of 10.0.0.1?
- I tried all combinations of above and the satellite will not connect. If I remove Cujo, the satellite works perfectly.
Any pointers would help tremendously.
Thanks,
