Ablac
May 07, 2017Guide
Orbi and CUJO working together
So I have an Orbi system (2 Sat) and I have a CUJO firewall. I wanted to share with everyone a way to get this working!!! It's quite a pain, but after spending 5 hours on the phone with CUJO support ...
TheEther
May 07, 2017Guru
This is kinda clever but can you explain why simply disabling the DHCP server on the Orbi doesn't work?
Ablac
Jul 24, 2017Guide
When you disable thw DHCP on the Orbi, you lose the ability to update Orbi over the Orbi interface. As well as the main orbi hub is unable to see the satellite’s. When you set them up under DHCP there able to view the satellite’s receive updates, as well as being protected by CUJO.
- CR-soundJul 24, 2017Aspirant
Not sure that this is quite right...since my cable modem is a router and provides dhcp, I have the orbi in AP mode with the cujo inbetween. If the orbi is not in AP mode, cujo can't see the individual devices, only the orbi main and the cable modem. Cujo is still protecting all Orbi connected devices since it sees the traffic through the orbi main. In terms of updating, Orbi does go out and check for updates and can see the satellites, so think that the AP mode is OK here.
