mdroyle's avatar
mdroyle
Orbi and Draytek issue
I have used the Orbi in AP mode v succesfully with BT Smarthub and also a Netgear modem. I now want to use a Draytek 2862 for the routing with Orbi still in AP mode. But when I introduce the Draytek the Orbi flashes magenta and I can't see it on the network - although I can see the satellite and other devices, and I can connect to the internet. So I can't administer the Orbi and unsure if devices can connect to it directly via wifi.
I assume there is a setting onthe Draytek that isn't correct but all views and insights welcome.
  • FURRYe38's avatar
    Try a power OFF of both new modem and Orbi for 30 seconds then back on.
    When in AP mode the Orbi RBR should get a IP address from the modem. Should setup the same way as the other modems.
    Try a factory reset on the RBR and setup from scratch and configure AP mode. Do other devices connected to the modem get an IP address?
  • FURRYe38's avatar
    Any progress on this?
