moelygaer's avatar
moelygaer
orbi and draytek vigor 130 no internet
SO my orbi rbk50 is working fine with a cheap and cheerful dlink modem. THEN I decide to upgrade the modem to a draytek vigor 130 and no internet connection. Good support from draytek established I could get a connection to the internet from my laptop so the problem is with the orbi router, all have been rebooted etc etc any ideas out there?
cheers
chris jones
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Have you tried to factory reset the unit by holding the reset button on the Orbi for 10+seconds then you will have to set up the orbi router again.
    DarrenM
    • moelygaer's avatar
      moelygaer
      I tried this, hard reset the orbi with the new modem attached and it worked YAY
      thanks for the help
