TV_Actor
Jun 18, 2017Aspirant
Orbi and Fixed Wireless Broadband
Before I purchase an Orbi system, I need to find out if it will be compatible with Fixed Wireless Broadband (provided by a line of sight radio signal). Not sure what else to say. Any first-hand exp...
TV_Actor
Hi, Pete...
Nope, this is going to be in the mountains of Colorado, USA. Peak Internet will be the provider and the service is called Fixed Wireless Broadband. There's an antenna on the roof that receives a line-of-sight radio signal containing the internety stuff. I havent moved in yet. The house is about 2200 square feet (204.39 sq meters) with a main floor and walkout basement.
Steve
Steve
st_shaw
Jun 18, 2017Master
Orbi should work for you in AP mode. It might not work for you in router mode, because wireless ISPs often use their own special routers.
