danesbury
Dec 13, 2018Aspirant
Orbi and managing wired connections
Hi
I have an Orbi RBK23 with two ports, one is connected to an umanaged Netgear 12 port switch and one goes to the sky hub router. There are two Orbi satellites.
Should I be able to plug into...
danesbury
Dec 14, 2018Aspirant
Thank you for the reply.
Attached is the configuration. I'm not quite sure what you mean when you mention 'behind' when it's a hub and spoke model?
danesbury
So, I put the ORBI into AP mode.
As you can see in the attached screen shot it is now picking up the wired connections. However I cannot switch them on and off, the slider buttons don't work, nor do they work for all the wireless devices wheras I was able to switch off the wireless networks prior to going to AP mode.
Secondly, I use Circle and now Circle cannot find the previous saved profiles as it cannot work in AP mode only in Router mode.
Should I go back to Router mode and somehow there is another way for the ORBI to recognise and manage the wired connections?
- michaelkenwardDec 14, 2018Guru - Experienced User
danesbury wrote:
Should I go back to Router mode and somehow there is another way for the ORBI to recognise and manage the wired connections?The situation you want is to have a single router on your network. Either the Skyhub or the Orbi.
Turning off the wifi on the Skyhub does disable the router bit. You'll have to work out how to put the Skyhub into modem only (bridge) mode. Ask Sky, or read the manual.
If you put the Orbi into AP mode, you will lose many features, probably including Disney Circle.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
- danesburyDec 14, 2018Aspirant
I see, I think I have to use my Sky Hub Router for the Sky service seems part of the contract.
If I put the Sky Hub into bridge mode somehow, should I leave ORBI in AP mode as it gives up a lot of features or if the Sky Hub is in bridge mode can I go back to router mode on the ORBI so I can control devices wireless and maybe wired even
Looking online seems Sky make it really difficult to use your own kit and bridge modes, I have a SkyQ system too.
I want to go back to Router mode on the Orbi, everything was working OK except I could not control the wired connections with the ORBI app. However, now I can't get back into the ORBI router to change it back, I've followed various instructions here https://kb.netgear.com/27199/How-to-troubleshoot-routerlogin-net-and-routerlogin-com-access-errors but can't get back in and I am loath to reset as it took me a day to set up all the wireless devices in the house.
