danesbury
Dec 13, 2018Aspirant
Orbi and managing wired connections
Hi
I have an Orbi RBK23 with two ports, one is connected to an umanaged Netgear 12 port switch and one goes to the sky hub router. There are two Orbi satellites.
Should I be able to plug into...
danesbury
Dec 14, 2018Aspirant
Thanks.
I just want to put it back to Router mode with the Sky Hub as it is with Wifi deactivated.
I can't get back into ORBI, I found the IP and I'm connected to it via WiFi,
192.168.0.32 is the ORBI and 192.168.0.1 is the Sky Hub Router.
The only problem for me putting ORBI back into Router mode is the loss of control of wired devices.
danesbury
