danesbury
Dec 13, 2018Aspirant
Orbi and managing wired connections
Hi
I have an Orbi RBK23 with two ports, one is connected to an umanaged Netgear 12 port switch and one goes to the sky hub router. There are two Orbi satellites.
Should I be able to plug into...
Dec 14, 2018Guru - Experienced User
Regarding Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
