MightyChadster
Aug 02, 2018Aspirant
Orbi and N300
Have an older N300 modem/router. Having trouble setting up new Orbi RBK40 system. Not technologically genius material here :-).
Aug 02, 2018Guru - Experienced User
What is the actual mfr and model# of this ISP modem/router?
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
- MightyChadsterAug 02, 2018AspirantThe modem is Netgear N300
