MightyChadster
Aug 02, 2018Aspirant
Orbi and N300
Have an older N300 modem/router. Having trouble setting up new Orbi RBK40 system. Not technologically genius material here :-).
MightyChadster
Netgear24 ?
Aug 02, 2018Guru - Experienced User
Cvna you go here and review the link on the right side of this page to help you idenfiy the model# of the modem?
https://www.netgear.com/support/
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
- MightyChadsterAug 02, 2018AspirantSorry. WNR2000v5
- FURRYe38Aug 02, 2018Guru - Experienced User
Ok, this is a wireless router:
https://www.netgear.com/support/product/WNR2000v5.aspx
Do you know the Mfr and model# of the ISP modem your using?
- MightyChadsterAug 02, 2018AspirantIt goes from the wall to that router with wethernet, not cable. There is no other modem. Just that Netgear. We have SurfAir Wireless here in Indiana.
