MightyChadster
Aug 02, 2018Aspirant
Orbi and N300
Have an older N300 modem/router. Having trouble setting up new Orbi RBK40 system. Not technologically genius material here :-).
Aug 03, 2018Guru - Experienced User
Ok, so you'll need to remove the WNR2000 router from the wall outlet and replace it with the Orbi router. Connect the wall outlet to the Orbi router and use a wire connected PC and a web browser and navigate to orbilogin.com or 192.168.1.1 and walk thru the setup wizard.
