airwolf666
Nov 07, 2018Aspirant
ORBI and NEST Hello
I was using a beta version software on my orbi and the beta test was complete so i upgraded the firmware to 2.2.1.210 and ever since my NEST hello goes offline a few minutes thru out the day and night. I had read thru the group that it could be a dns issue if it happen around the same time, so i changed and assigned it it's on IP address so I could try to rule that out. I have now down graded to version 2.1.4.16 and it still keeps going offline. I have done factory resets on the orbi and still happens. Does anyone have any suggestions.
I ended up using a WiFi extender that I had laying around. It is a Netgear EX6100 and using it in extender mode and using the fast line to the router on 5 ghz band, that leaves me using the 2.4 ghz band to the Nest Hello which for some reason it likes only using that. When using the fast lane you have to choose which band you want to talk with the router and then the other band are for your devices. Since I have done this I have not had any discounts from the internet.
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try disabling the following and see:
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
Have you factory reset the NEST and set it up from scratch?
Contact the NEST mfr for additional help and information as well.
- airwolf666Aspirant
I currenlty am using a Netgear CM1000 cable modem thru Cox communications.
The Orbi is in Router mode.
1750 square feet is the home size. The router is located in my office which is in the front of the house and is located 6 feet away the NEST hello. The satellite is about 25 to 30 feet away. One satellite is used RBS50.
I am using Auto I can try switching.
Lots of WiFi neighbors by 8 to 10.
Using WPA2-PSK (AES)
I currently have unchecked Enable Implicit Beamforming and Enable MU-MIMO
I can try missing around with the daisy chain, but don't think that matters to me as i only have the one satellite.
Yes I have done a factory reset and set up, which is not fun.
Lets try enabling Beamforming.
You can try and run a test. Turn OFF the satellite while working with the camera to ensure it's getting connected to the main router first. If you can get it connected well, then turn on the satellite later.
