vuongman
Jan 31, 2017Tutor
Orbi and Nest Outdoor Camera issues
I just install the ORBI mesh system and although the speed is fantasic, my two Nest outdoor camera seems to be losing signal(disconnecting) several times a day. Over 10 minutes sometimes. This happen...
susiepratt
Apr 23, 2017Tutor
Yes I did. The tech support also confirmed that same "fix", but it did not work for me. He told me to take my system back.
StevenT
Apr 23, 2017Aspirant
I guess I have been lucky. I installed an Orbi a couple of weeks ago, and have a range of Nest cameras on my network (ranging from older dropcam pro to newer Nest cam outdoor). They were frequently dropping connection, but after I turned off implicit beamforming, I haven't noticed any connection problems with the cameras.
- gfreyApr 24, 2017Apprentice
I have a couple Dropcams, Nest Cams, and now two outdoor Nest Cams. I bought the Orbi system when it was first released and had the issue of the cams disconnecting. When the solution was to Uncheck the "Enable Implicit BEAMFORMING" option came about, I haven't had one single disconnect. I keep Implicit Beamforming off and check it after every firmware update.
- Toy4wdApr 25, 2017Tutor
I have continued to have the issues. Definately decreased but constant drops not only for my cameras but for my devices as well. Very frustrating and will eventually buy another Wifi system if it persists, give this to my mom or something, sad.
- DarrenMApr 27, 2017Sr. NETGEAR Moderator
Hello Toy4wd
I have sent you a PM
DarrenM
- DarrenMMay 03, 2017Sr. NETGEAR Moderator
Hello Everyone
We currently have a beta firmware for issue with Nest cameras if you would like to test this firmware send me a Private message with your name, Email, and phone number then our support team will work with you and provide the beta firmware.
Thanks
DarrenM
- Danielt9Jul 31, 2017Aspirant
Can you please send me the new firmware. I have had continuous issues with my Nest and am close to returning the router.
- Mikey94025Jul 31, 2017Hero
You're replying to an old thread. The latest publicly-available firmware version, V1.12.0.18, resolves the previous issues with Nest cameras. You should be able to auto-update your Orbi to get this firmware version. I've had zero disconnects with this firmware version and my 5 cameras (with implicit beamforming and MU-MIMO re-enabled).
- idagzAug 18, 2017Aspirant
After the update, I'm still having issues in both of my cameras.
