vuongman
Jan 31, 2017Tutor
Orbi and Nest Outdoor Camera issues
I just install the ORBI mesh system and although the speed is fantasic, my two Nest outdoor camera seems to be losing signal(disconnecting) several times a day. Over 10 minutes sometimes. This happen...
gfrey
Apr 24, 2017Apprentice
I have a couple Dropcams, Nest Cams, and now two outdoor Nest Cams. I bought the Orbi system when it was first released and had the issue of the cams disconnecting. When the solution was to Uncheck the "Enable Implicit BEAMFORMING" option came about, I haven't had one single disconnect. I keep Implicit Beamforming off and check it after every firmware update.
Toy4wd
Apr 25, 2017Tutor
I have continued to have the issues. Definately decreased but constant drops not only for my cameras but for my devices as well. Very frustrating and will eventually buy another Wifi system if it persists, give this to my mom or something, sad.
- DarrenMApr 27, 2017Sr. NETGEAR Moderator
Hello Toy4wd
I have sent you a PM
DarrenM
