vuongman
Jan 31, 2017Tutor
Orbi and Nest Outdoor Camera issues
I just install the ORBI mesh system and although the speed is fantasic, my two Nest outdoor camera seems to be losing signal(disconnecting) several times a day. Over 10 minutes sometimes. This happen...
georgebalanchin
Sep 05, 2017Tutor
I think I'm having the same issue with my Arlo Q and Nest Cam Indoor. Any tips on what should I do?
DarrenM
Sep 07, 2017Sr. NETGEAR Moderator
Hello george
Can you give some more detail on the issue you are having.
DarrenM
- ufgators2kOct 30, 2017Aspirant
This issue still seems to be prevalent. I have a Nest Outdoor Cam that disconnects more than half the day. I checked my Wi-Fi speed, both upload and download, and they are both excellent (200Mbps down/25Mbps up). When will the Orbi be fixed for the dropouts?
- Mikey94025Oct 30, 2017Hero
Most other Orbi users no longer have any issues or dropouts with their Nest cameras. We need to figure out what's different about your environment.
What version of the firmware are you running? Have you tried toggling the Implicit Beamforming and/or MU-MIMO settings? With the latest V2.0.0.74 firmware there's no need to toggle these settings but let's see if they affect your environment. I don't have any disconnects or dropouts with my Nest indoor, Nest outdoor, and Arlo cameras.
- idagzOct 30, 2017Aspirant
Update...I have upgraded to the latest Outdoor Nest Cams and the issue went away. No more disconnects.
