MightyT's avatar
Aug 23, 2016
Orbi and other Routers
Does the Orbi Satellite work with other Netgear AC Routers?
  • No.
    You would need the Orbi router to have a wired connection to the R6300 using Ethernet if you want to use both R6300 and the Orbi and put one of the Orbi router or R6300 in access point mode.
    The Orbi Satellite connects to the Orbi router only.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello MightyT
    Can you be more specific with the question? Are you asking if you can connect the orbi to existing routers?
    DarrenM
      • DarrenM's avatar
        DarrenM
        Hello MightyT
        Yes you can either use orbi as your main router and connect the R6300 to it and make it a access point or you can connect the orbi to the R6300 and make it a access point.
        DarrenM
