GonzodD's avatar
GonzodD
Follower
Jan 24, 2019
Orbi and second switch setup
I upgraded my RK6300 router to ORBI RBK53, but the ORBI has one less Ethernet port.
I am needing best 5 port switch recommendation.  My home system has internet Ethernet going to modem then direct line to ORBI, then back to 8 port ProSAFE GS108 so each room in house has hard line.
Can I add another switch to ORBI for Receiver, BluRay, TV, and ROKU?
Need 5 port switch recommendation that will maximize Internet speed.
Thanks,
Dave
  • FURRYe38's avatar
    As long as the switches are not managed, smart or have Green Ethernet, you'll be fine with the GS105/108 series.
    You can daisy chain them as well so you could have multiple switches in between the router and satellite. I have three in between my one satellite.
    Thanks,
    Dave
  • FURRYe38's avatar
    Any updates on this? Hope you were able to find what you were looking for.
    Thanks,
    Dave
