walkerx
Feb 24, 2019Guide
Orbi and Sky
I heard that netgear had enabled the ability for some of their devices to work with Sky and its MER configuration, does anyone know if this will happen with the Netgear Orbi or are we assigned to usi...
Feb 24, 2019Guru - Experienced User
You would need to contact Sky and ask them what specifically they support on there system for use with there ISP hardware. See if they support the Orbi working on there system handling the ISP connection.
- walkerxFeb 24, 2019Guide
Sky will not divulge that information to any customer, but the router has to be able to support MER connections using Option 60/61
