walkerx
Feb 24, 2019Guide
Orbi and Sky
I heard that netgear had enabled the ability for some of their devices to work with Sky and its MER configuration, does anyone know if this will happen with the Netgear Orbi or are we assigned to usi...
walkerx
Feb 24, 2019Guide
FURRYe38 wrote:
Might contact NG support and see then.
https://www.netgear.com/support/contact.aspx
If the Sky modem offers a DMZ option on there modem HW, then you could use the Orbi in router mode. If not, and Orbi doesn't support this MER configuration, then AP modem would be last resort.
I currently use a HG612 as modem, then Opnsense for the connection with the Orbi being used as AP for Wifi access only
Feb 24, 2019Guru - Experienced User
What happens if you replace the Opensence with the Orbi RBR in place with the modem. Doe it not work?
