walkerx
Feb 24, 2019Guide
Orbi and Sky
I heard that netgear had enabled the ability for some of their devices to work with Sky and its MER configuration, does anyone know if this will happen with the Netgear Orbi or are we assigned to usi...
Steven_Belfast
Feb 24, 2019Apprentice
@walkrex
Why not just use the Sky Hub in conjunction with Orbi
That’s the way I am using it.
Orbi in Ap mode, wireless disabled on the Sky Hub and it works fantastic.
Feb 24, 2019Guru - Experienced User
Does your modem have a DMZ feature?
Steven_Belfast wrote:
@walkrex
- Steven_BelfastFeb 24, 2019ApprenticeFURRYe38
The Sky Hub’s do have the option,
However I do not use it.
Once Orbi is set to AP mode all firewall function are turned off on Orbi and so only the Sky Hub uses a firewall.
I also have DHCP off on Orbi and it’s handled by the Sky Hub 2
